Hi !
I was trying out a simple led flasher circuit from a kit ( was supposed to be built in hardware) and I am using multisim.
It calls for an inverter gate which I can find two kinds of # 4001 is a nor gate as but it is either a single gate or a quad integrated chip. Anyway could not get it to work :-( in my project. But that is not the issue now or I would post the specs which I know you may need to help. What I really wanted to know does the single nor gate with the three - 2 in -1 out leads, function without a power supply because it does not have any pins for + - voltage???
I can not imagine how it would, since if you apply ground to both inputs 0 volts is never going to be 5 volts out! But no added pins on this software gate. Any help is appreciated , I know it is a simple solution but have not figured it out.
