Gate resistence for MOSFET?
Discussion in 'The Projects Forum' started by vivek20055, Dec 11, 2012.
  1. vivek20055
    Nov 4, 2012
    88
    what is the value of gate resistance that must be used before MOSFET for switching operation?
    Thanks & regards,
    Vivek Alaparthi
  2. ErnieM
    Apr 24, 2011
    7,435
    1,625
    One typically aims for zero ohms.
  3. wayneh
    Sep 9, 2010
    12,374
    3,225
    Are you asking what resistor to use, connected to the gate?
    The purpose of the gate resistor is to limit the inrush current to some level that is safe for both the MOSFET and the device driving it. It may not be needed, and using a resistor will slow the transition time to charge and discharge the gate.
    Choosing the right resistor becomes increasingly important at higher frequencies.
    So, you'll get a better answer if you supply the experts here more details about what you are doing.
  4. vivek20055
    Nov 4, 2012
    88
    Thank you for your reply.I am designing a Induction heating system. I am using using the Mosfets for switching purpose and gate drivers(LM5112) for driving the MOSFETS.
    I am attaching the circuit diagram with this post and the PDF of LM5112 gate driver. In page number 9 you can find information regarding gate resistance.
    Could you please assist me with the value of gate resistance I need to use here.
    Thanks in advance ,
    Vivek Alaparthi
  5. wayneh
    Sep 9, 2010
    12,374
    3,225
    Don't. Not needed.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You're showing a schematic, but not what kind of comparator/opamp you're using, and I'm not certain what frequency you're considering operating it at - perhaps 1MHz with a rise/fall time of 2ns?
    Board layout would be critical at high frequencies. The gate charge requirement for the MOSFET will act like a small capacitor, and the trace from the gate driver to the gate will have inductance, creating a series-resonant circuit that will ring like a bell when you place a fast-changing signal on it.
  7. shortbus
    Sep 30, 2009
    4,088
    1,670
    Like Sgt. says keep driver as close to the mosfet as possible. On application note I think it was from International Rectifier said to keep the driver under 5/8 inch from the gate. And same note said a 4.7ohm to 25ohm resistor is what to use.
    Again like Sgt. said, to stop "ringing" on the gate, which is very bad for the mosfet.
  8. vivek20055
    Nov 4, 2012
    88
    Hello Shortbus,
    Thanks for your reply.
    Can you provide me the link for data sheet of International rectifier that contains the note of Rgate.
    Best regards,
    Vivek Alaparthi.
  9. shortbus
    Sep 30, 2009
    4,088
    1,670
  10. Ron H
    Apr 14, 2005
    7,050
    657
    I don't see an LM5112 in your schematic.:confused:
