Gate Driver for Electric Motorcycle (MOSFET)
Discussion in 'The Projects Forum' started by jegues, Oct 31, 2013.
  1. jegues
    Sep 13, 2010
    735
    43
    Evening gents,
    I am currently trying to design a suitable gate driver circuit for a half bridge circuit for an electric motorcycle.
    The half bridge will be composed of MOSFETs and FWD (in either a module or made from discrete components) and a battery bank of ~55V and operating with switching frequency of 15-20kHz.
    I've seen how gate drive chips can be used with charge pump and bootstrap capacitor circuitry in order to drive the high side switch, but I've also heard that it can be done with a DC-DC converter.
    Can someone explain to me how this done, or point me towards a good reference?
    Also, can anyone suggest a suitable gate driver for our particular application?
    Thanks again!
  2. ronv
    Nov 12, 2008
    3,403
    1,477
  3. wayneh
    Sep 9, 2010
    12,392
    3,246
    $10 to avoid the bootstrap capacitor? Seems like overkill to this casual observer.
  4. ronv
    Nov 12, 2008
    3,403
    1,477
    You can't run a motor at 100% duty cycle with a bootstrap capacitor. I would think he wants 100% power. Since he only seems to want to go forward this might be easiest.
    shortbus and wayneh like this.
  5. jegues
    Sep 13, 2010
    735
    43
    We are actually planning on implementing regenerative braking in the converter as well.
  6. ronv
    Nov 12, 2008
    3,403
    1,477
    In which case you need the high side FET, not just the diode. I would think the charge pump driver would be easiest.
