Garog V60 Roller Shutter Auto Doors
Discussion in 'Embedded Systems and Microcontrollers' started by firdano, Sep 6, 2008.
  1. firdano
    Sep 6, 2008
    Hii all.
    I'm having problem with this micro controller ST62T25B6-HWD. Its having stop mode instead open mode.
    If anyone could find me the circuit diagram of garog V60 to troubleshoot the components.
    Thank you.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Are you sure the part number of the microcontroller is correct?
    ST Microelectronics has the ST6225Cx microcontroller datasheet here:
    http://www.st.com/stonline/products/literature/ds/5266/st6225c.pdf
    The ST62T25C is an OTP (one-time-program) part.
    I cannot find a reference to Garog anywhere on the net besides your thread here.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    firdano,
    Is garog possibly meant to be "garage"?
    I have seen some roller shutter style doors for garages.
    hgmjr
  4. firdano
    Sep 6, 2008
    Yes sargentwookie.it is correct the part number.I did order the same memory map and pin location and burnt it into the ic.ST62T25CB6.(28pin)
    The problem is i did change almost 'all new' component on the board still the board didnt work out.
    The company that installed it moved out to india and did not leave anything.
    Dear moderator..Garog is a roller shutter brandname from united kingdom or germany I think. I did try to surf but cannot get the info about it.
    This board installed in 1998 and used for underground car parking.User 'touch' the mifare card reader and the roller goes up.once the car go in the roller goes down again.it is the same process again and again.
    thanks
