Galvanically Isolated MOSFET/IGBT Gate Drive
Discussion in 'General Electronics Chat' started by ashkarmalik, Jul 7, 2015.
  1. ashkarmalik
    Jul 1, 2012
    55
    Hello Peoples,
    I am working on a High Voltage MOSFET/IGBT gate driver that is to be used as a half bridge with independent control signal from a isolated source(M.C.U) . I need to drive high power IGBT 600v @ 100A .With a sampling frequency of 15khz to 25khz.
    The main problem is the availability of off-the-shelf Isolated drivers and the huge cost involved to buy them.
    Could some one through some light on a the Gate driver for our purpose.
  2. #12
    Nov 30, 2010
    16,703
    7,341
    The first thing that comes to mind is an opto-isolator and a gate driver chip.
    I'm not the best at this design; I can't name the chips right now, but I believe they are fast enough for the job.
    Roderick Young likes this.
  3. ashkarmalik
    Jul 1, 2012
    55
    Your Solution would be a good Start up Design.But I think Transformer Coupled Driver with a Dedicated GDT would be a better option .
  4. #12
    Nov 30, 2010
    16,703
    7,341
    OK. So, what is your question? Looking for a current driven, isolated gate driver?
  5. ashkarmalik
    Jul 1, 2012
    55
    Exactly!
    You Got the Idea.
    I got this Schematic From Internet,So You Would Get An idea what Configuration I need.
  6. #12
    Nov 30, 2010
    16,703
    7,341
    Now you're completely outside my abilities. Be patient. Smarter people than me will be on site after the sun comes up in the western hemisphere.
    (I don't mean we don't have some great engineers in western Europe, I mean they don't usually log in at this time of day.)
  7. shortbus
    Sep 30, 2009
    4,095
    1,685
    MaxHeadRoom likes this.
  8. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Although the IR2110 will not isolate the drive logic from the mains powered bridge.
    Vss & COM (13 & 2) must be connected.
    Also with no high side switching the IR2110 is not really needed.
    Max.
  9. ronv
    Nov 12, 2008
    3,401
    1,459
  10. ashkarmalik
    Jul 1, 2012
    55
    The main Problem is to make a Galvanic-ally isolated IGBT Gate driver for my Controller card.
    So a Discrete system based Gate driver with Transformer coupling is required.[​IMG]
  11. ronv
    Nov 12, 2008
    3,401
    1,459
    So are you saying you already have a board and need a replacement transformer?? If so which schematic?
  12. cmartinez
    Jan 17, 2007
    3,698
    2,788
    If you want to completely isolate the triggering signal from the mosfet, I suggest you take a look at this circuit designed by @JDT. I've successfully used it before myself, and I believe it's perfectly capable of working at the 25Khz frequency that you want.
  13. shortbus
    Sep 30, 2009
    4,095
    1,685
    I went with those because in the first post he said "half bridge". And to me a half bridge is one high side and one low side switch, correct? One of those "moving goalpost" threads it seems.
    And while not "galvanic" the isolation of those gate drivers are guaranteed to 600V according to the data sheets.
  14. #12
    Nov 30, 2010
    16,703
    7,341
    That's the opto-isolator and gate driver I suggested in post #2.
  15. cmartinez
    Jan 17, 2007
    3,698
    2,788
    I really really really need to sharpen my observation skills... that, or maybe I've just had enough for today...
  16. #12
    Nov 30, 2010
    16,703
    7,341
    When the TS isn't very sure about what's available, it gets as bad as a "twenty questions" thread where we try to pry the information out, one question at a time. I don't mind the threads that are driven by ignorance. That is a valid reason for asking.
    shortbus and cmartinez like this.
  17. Lestraveled
    May 19, 2014
    1,957
    1,218
    I am going to try reading between the lines. I think the TS is looking for a high side mosfet driver that can operate at greater than 100 volts and not be a pain to implement.
    Look at the On Semi NCP5181. It might do what you are looking for. The off the shelf, high voltage, high side, mosfet drivers are not really there yet. (Pretty slow for today's switching speeds.) Look especially at the "Allowable output slew rate".
  18. ashkarmalik
    Jul 1, 2012
    55
    I think there is confusion on what I want to achieve,So I just Clarify that first.
    I am Working on a Motor Drive With 6 IGBT to be controlled.These IGBT Should Be working in the 20~ 25 Khz Range.
    These IGBT Modules are rated at 600v @100~200A each.Since Supply voltages are high (~150v).So I need to provide Isolation to my Gate driver so as in any Mis-happening these IGBTs Doesn't Blow up my Logic system.This is the reason I want to design a GDT based Isolation and IGBT Driver Circuit.I doesn't have any Schematic of the GDT based Driver circuit.So I am in need of a Good Reference design.
  19. Ancel UnfetteredOne
    Member
    Jul 3, 2015
    36
    14
    I did something similar just last week....galvanically isolated gate voltage using a 'charge pump' design.
    Here's the LTspice of it.
    You'll prob. have to alter the design to suit your voltages.
    Bat PWM Sw Cap.asc
    cruts, helped me with this!
  20. ronv
    Nov 12, 2008
    3,401
    1,459
    What we don't understand is why you would rather use a transformer that an opto isolator. Both provide the isolation you are looking for.
    http://www.mouser.com/Passive-Compo...yzf3ke&Keyword=gate+drive+transformer&FS=True
    http://www.mouser.com/new/optoelectronics/optocouplers-photocouplers/high-speed-optocouplers/n-6zsft
