Galvanic isolation
Discussion in 'General Electronics Chat' started by Vijayan11oct, Apr 22, 2015.
  1. Vijayan11oct
    Apr 22, 2015
    What is the industry standard for galvanic isolation? How to provide galvanic isolation?
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    I'm not sure there is a standard. Most of the standards I've ever encountered were nearly useless from a practical point of view.
    The following article may provide some insight and references for you.
    http://en.wikipedia.org/wiki/Galvanic_isolation
    Vijayan11oct likes this.
  3. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    I imagine it will vary to some extend as to the voltage level and the environment you are working in?
    Max.
  4. wmodavis
    Oct 23, 2010
    737
    150
    A standard component to achieve galvanic isolation is of course the good ole dual winding transformer.
  5. Papabravo
    Feb 24, 2006
    10,338
    1,850
    And the ever popular optoisolator, where information travels on small beams of light.
  6. crutschow
    Mar 14, 2008
    13,469
    3,356
    There is no standard. It's however much isolation the particular application requires.
    Common methods for galvanic isolation are transformers and capacitors for AC signals.
    Electromagnetic waves can also be used for isolation such a opto isolators or other RF transmitters and receivers.
