How do you determine the gain in a car antenna booster?? Pleas help Thanks.
C Thread Starter Carlost Joined Jul 9, 2007 8 Sep 13, 2007 #1 How do you determine the gain in a car antenna booster?? Pleas help Thanks.
bloguetronica Joined Apr 27, 2007 1,541 Sep 13, 2007 #2 Normally the gain is defined by the relation Vout / Vin for a signal having voltage Vin. I presume that is the same with a car antenna, assuming that the signal received by the antenna is converted to voltage. Check this link: http://en.wikipedia.org/wiki/Gain PS: Google does wonders!
JoeJester Joined Apr 26, 2005 4,390 Sep 13, 2007 #3 Gain is as cumesoftware stated. What specification did your car booster say on the packaging? Typically they are 10 to 20 dB gain.
C Thread Starter Carlost Joined Jul 9, 2007 8 Sep 14, 2007 #4 well that what im trying to find out it dint say what it was. i tryed to use the first method...Vin/Vout but it seems not to work. any other ideas??
JoeJester Joined Apr 26, 2005 4,390 Sep 14, 2007 #5 20 * log (Vout / V in) will give you the gain in dB.
