Gain of op-amp amplifier with potentiometer
Discussion in 'Homework Help' started by ham3388, Jun 10, 2016.
  1. ham3388
    Jul 3, 2012
    97
    Hi dears
    Below is a worked example with solution from the university material plus an assignment asking for solution. I did solved it but I am not sure about my solution. Could you please go through it and give some kind of help and support to understand it or give some means to solve it if it is incorrectly been solved.
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    @shteii01 , you forgot to take the 100 K resistor (R3 in the schematic) between the output of the opamp and the 1 K resistor to ground into account.
    Bertus
  3. DGElder
    Member
    Apr 3, 2016
    347
    87
    Ham, I think you may be confused about how a potentiometer works- Rp is not R3: Look up potentiometers in Wiki.
    It is the same circuit as the example with variations only in R3 and R4 and you are given the gain formula in the example. All you have to do is figure out R3 and R4 which depend on the pot wiper position, "x", and then plug the numbers back into the gain formula. For example: Part b) R4 = x*10K + 1K = 8k and R3 = (1-x)*10K = 3K.
  4. shteii01
    Feb 19, 2010
    3,500
    511
    I modeled Part A. Part A has the pot set to 0 Ohm.
  5. DGElder
    Member
    Apr 3, 2016
    347
    87
    shteii01, the model is not correct for any of the parts. Look up potentiometers in Wiki to see how they work.
  6. shteii01
    Feb 19, 2010
    3,500
    511
    Draw the circuits for each part of the problem and post them.
  7. ham3388
    Jul 3, 2012
    97
    Thanks friends. , I will go through the Wikipedia then I will get back to you guys. :)
  8. shteii01
    Feb 19, 2010
    3,500
    511
    Ok. I see what I did wrong earlier. The pot resistance does not just go away. It moves as the junction moves. When x=0, the whole resistance of the pot is "above" the junction, or, as bertus said, the 10 kOhm resistor is between output of op amp and the junction of the 100 kOhm and 1 kOhm resistors.
  9. ham3388
    Jul 3, 2012
    97
    I went through the Wikipedia and other resources and recalculated it based on those resources plus guidance from Mr. DGELer and Mr SHTEII01.
    Could you please look on the below attachment and give your comments.
  10. The Electrician
    Oct 9, 2007
    2,300
    335
    I think you have the x=0 and x=1 cases reversed. x is the fraction of the potentiometer measured from the bottom.
  11. dannyf
    Sep 13, 2015
    2,196
    417
    the inverting end is at round. So current flows from V1 to the inverting end and then R2 and then to Vx. That current is I1 = V1 / R1.
    So Vx = - I1 * R2 = - V1 / R1 * R2.
    The current flows from ground to Vx through R4: I4 = -Vx / R4.
    I1 + I4 flow through Rp to Vout.
    Vout = Vx - (I1 + I4) * Rp = Vx - (V1 / R1 - Vx / R4) * Rp = (-V1 / R1 * R2) - (V1 / R1 + V1 / R1 * R2 / R4) * Rp = (V1 / R1) * (-R2 - Rp - R2 * Rp / R4).
    In this case, it is 11.1v.
    It can be re-expressed to be more intuitive.
  12. DGElder
    Member
    Apr 3, 2016
    347
    87
    Ham, only in part b) are the R3 and R4 values correct. If x=0 that means the wiper is at the bottom of the resistor (zero distance from the bottom), so the entire 10K is above the wiper. When X=1 the wiper is at the top so that the entire 10K is below the wiper. My formula for R3 and R4 applies for all wiper positions. Post #8 correctly represents the pots contribution for x=0.
  13. Jony130
    Feb 17, 2009
    3,990
    1,115
  14. ham3388
    Jul 3, 2012
    97
    Thanks friends. ..I think I got it
    Cheers
  15. dannyf
    Sep 13, 2015
    2,196
    417
    another approach would be to think of it from Vout's perspective: Rp and R4 are in parallel. So the feedback resistance is R2 + Rp//R4.
  16. The Electrician
    Oct 9, 2007
    2,300
    335
    Are you saying that the feedback resistance is R2 + Rp||R4, therefore the gain is -(R2 + Rp||R4)/R1? Is this for the case x = 0? It isn't the same as the correct expression you gave in post #11: (-R2 - Rp - R2 * Rp / R4)/R1
  17. DGElder
    Member
    Apr 3, 2016
    347
    87
    The text's gain derivation was a bit difficult to follow and cookbookish, but I got the same answer, -1020, deriving from basic ideal op amp principles - shown in attached image.
    For the potentiometer version I got:
    x=0, G = -111
    x=0.7, G = -14
    x= 1.0, G = -10
  18. ham3388
    Jul 3, 2012
    97
    For the potentiometer version I also got
    x=0, G = -111
    x=0.7, G = -14
    x= 1.0, G = -10
  19. dannyf
    Sep 13, 2015
    2,196
    417
    Think from Vout's perspective. Vout + Rp (serial) can be viewed as a current source of Vout/Rp + Rp (parallel).
    Rp in parallel + R4 in parallel -> Rp//R4 in parallel, with a current source of Vout/Rp -> a voltage source of Vout * (Rp//R4) / Rp + Rp//R4 in serial.
    The rest is similar to a typical inverting amplifier.
    This approach is used to form large feedback resistors.
    A good approach for a voltage amplifier. A terrible approach for a transimpedance amplifier.
  20. dannyf
    Sep 13, 2015
    2,196
    417
    if you want to work out a generic form with the wiper, just work the wiper position into Rp and R4.
