Gain of a push-pull BJT amplifier? (Basic)
Discussion in 'Homework Help' started by Fraser_Integration, Oct 8, 2010.
  1. Fraser_Integration
    Nov 28, 2009
    142
    5
    Hello. For my lab project this semester i have to build an audio amplifier that has an pre-amp stage using op-amp circuits, and an output stage using a BJT power amplifier, all to be driven by 3 or 4 1.5V batteries. Class B / AB has been suggested. My University is annoying in that it gives you the practical before the theory so you are inclined to do research yourself but I am not getting far.
    Two things I wanted to ask, in the norman push-pull arrangement as in this link from the project pages: [​IMG],
    what will be the gain of the arrangement? If it is dependent on beta, is that not bad practice?
    Also, mroe generally, do you think having a simple non-inverting amplifier op-amp set up for the preamp, feeding into a BJT amplifier for the output stage is sensible?
  2. Jony130
    Feb 17, 2009
    3,995
    1,117
  3. Fraser_Integration
    Nov 28, 2009
    142
    5
    the current gain then maybe!
    why do they call it a push-pull amplifier if you don't get any amplification of the input signal?
  4. Jony130
    Feb 17, 2009
    3,995
    1,117
  5. Fraser_Integration
    Nov 28, 2009
    142
    5
    Ah, thank you very much. That is most useful.
