Gain in ina114 is not obtained
Discussion in 'The Projects Forum' started by nakulnasa, Oct 16, 2010.
  1. nakulnasa
    Oct 15, 2010
    8
    Hi i am using ina 114 for my signal conditioning circuit.According to the calculation the G=1+(50k/Rg). When i set the Rg value to 50k the gain must be 2 an if i give 10 mv of input to the non inverting terminal the output must be 20mv but the output is 647mv till the input is 550 mv. Can any body help me out.
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Post your schematic.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    The INA114 requires a dual-rail supply; it will not work properly with a single supply.
    If you must operate an instrumentation amplifier with a single supply, you need to select a different model.
    nakulnasa likes this.
  4. nakulnasa
    Oct 15, 2010
    8
    Thanks for ur information. I have now optimized my circuit for ina 114 using single supply. I have made an virtual ground with vcc/2 (using the voltage divider circuit) to the inverting terminal (PIN 2)and i have connected the Vref (PIN 5) of ina114 to the virtual ground. And by giving the input to non inverting terminal (PIN 3) with respect to the virtual ground and by measuring the output from the Vout (PIN 6) with respect to the virtual ground i am obtaining the gain exactly what required(only the range of the output voltage is reduced to 0v-1.5v when vcc is 5v, and 0v-3v when vc is 12 v). I want to provide the input and measure the output with respect to the system ground. Is this possible can u please help me out...
    Thank you..
  5. nakulnasa
    Oct 15, 2010
    8
  6. nakulnasa
    Oct 15, 2010
    8
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Sure. Add a negative supply rail, and get rid of your virtual ground.
    Either that, or get an instrumentation amplifier that is rated for single-supply operation who's input and output range includes ground.
  8. nakulnasa
    Oct 15, 2010
    8
    Thanks...Since my circuit is battery powered i cannot go for the negative supply , i have to work with the single supply....
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    So use two batteries in series, with the junction in between them grounded.
    Or, use a DC-DC converter like an ICL7660 to generate a negative rail from the positive rail.
  10. nakulnasa
    Oct 15, 2010
    8
    Thanks ..i got the output...
  11. zabeeb
    Dec 15, 2014
    i m using INA114 in my project but i cant find it in proteus software . any one please help me how can i add this or other options to use this in simulation .
  12. zabeeb
    Dec 15, 2014
    how did u made INA 114 in prepteous ??? can u please tell that to me
