Gain in dB
Discussion in 'Homework Help' started by Hello, Mar 30, 2009.
  1. Hello
    Thread Starter Active Member
    Dec 18, 2008
    82
    Calculate (i) the gain in dB at 10kHz and (ii) the cut-off frequency for
    R = 100W and C = 1μF if the input voltage = 10V.
    Any help is appreciated.
  2. ABoul
    Member
    Mar 30, 2009
    15
    can you get the gain itself? because the gain in dB is simply 20log |G|, where |G| is the modulus of the gain, and that's log to the base 10.
  3. Hello
    Dec 18, 2008
    82
    But how would i work out the output voltage?
  4. ABoul
    Member
    Mar 30, 2009
    15
    what you have there is a potential divider. let X denote the impedence of the capacitor, so that X = 1/jwC. the output voltage would therefore be V_out = V_in[X / (X + R)]. from there, you can divide by V_in to get V_out/V_in, plug in your numbers, find the modulus and 20log it.
  5. scythe
    Mar 23, 2009
    49
    5
    you're asking for help on your exam?
  6. ABoul
    Member
    Mar 30, 2009
    15
    past papers are a great way to prepare for your REAL exams. in fact, it's the only way i prepare for them.
  7. Hello
    Dec 18, 2008
    82
    You're right! Thanks for the help.
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    If so, I think he already failed about 10 months ago (exam dated May/08). :p
  9. ABoul
    Member
    Mar 30, 2009
    15
    what goes inside the log is |Vo/Vi|, NOT Vo.
  10. thatoneguy
    Feb 19, 2009
    6,357
    718
    @ 10kHz ≈ -16dB (I believe you had a typo)
    -3dB / 45° cutoff ≈ 1.6kHz
    Filter is 2nd order low pass filter, attenuation -6dB/octave after cutoff point.
    Always check other calculations to see if they "make sense", i.e. 10kHz is about 4x 1.6kHz, so either -dB per octave is way too low for attenuation, or the 10kHz calculation is incorrect. :)
