Gadget Design (RF Emitter?)
Discussion in 'General Electronics Chat' started by mdaws, Jul 29, 2007.
  1. mdaws
    Jul 29, 2007
    I'm trying to design a small gadget for a class project, and I was hoping to get some help with the necessary components.
    Part I: I want something like 2 plates when they are in close proximity that can emit some sort of signal. (I was thinking maybe there is a cheap commercial form of something similar to RF id cards?)
    Part II: I want another two plates which can pick up the signal from Part I if it is emitting and when these two plates themselves are separated and the other two plates are close a sound is produced.
    Thanks!!!
    Matt
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    That sounds a bit other worldly. Is there some new physiscs in there? I'd be fascinated to learn more.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Your description is a bit hard to imagine. Can you expand on the concept of "plates"? To take a guess about something that might be satisfactory, google "theramin" for an idea.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Er, it's "Theremin" there, beenthere ;)
    That's your starting point - a Theremin (named after it's inventor.)
    Google that, and look at the Wikepedia entry. See if it fits.
  5. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    You can hand wind a couple of coils, one coil is fed by low voltage AC and the other one goes to a speaker. You can even have the 2nd coil be powered by the ac and make it louder. It's not efficient but it works. Easiest is to light an LED.
