Resistors have a power rating. This means that they usually can work at a range of voltages as long as it is not so high as to increase the amperage to a high enough level to cause excessive wattage to be dissipated through the resistor to cause it to burn up.
This would lead one to believe that fuses work on this concept as well. Excessive amperage causes excessive wattage which would cause the fuse to melt.
However, how is it that a fuse marked 250 20 amp can be used to provide over current protection at a lower voltage? (20 amp 120 volt is 2400 watt while 20 amp 250 volt is 5000 watt)
