Fuse
Discussion in 'The Projects Forum' started by Lightfire, Apr 12, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    OK.
    Materials specs
    battery 12 volts 12 ah (as usual :D)
    fuse (12 volt/1 ampere (let's say))
    bulb (12 volt/5w :D :D)
    Ok, the line 1 joined the terminal - and + causes it to short-circuit. but it's have own fuse to protect itself. :D so, it will not affect the line 2?
    as you may notice, both line have their own connection. they are directly put on the battery.
    um,what's your comment? am i correct? i hope so.;)
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    It takes time (maybe 1 second or two seconds because the battery is not very powerful) for the fuse to heat up then burn out. During this time the the battery is shorted by line 1 and the light bulb will be very dim.
  3. Lightfire
    Oct 5, 2010
    690
    21
    But after one or two seconds, the light brightness will back to normal?
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    I guessed one or two seconds because I don't know your battery and I don't know your fuse. The fuse might burn out in 10 seconds.
    When the fuse burns out then the battery returns to normal with only a small anount of its charge gone.
