Hopefully this should be a simple obvious question!!
I'm using a length of nichrome wire on a 12v supply to create some heat for my project.
It draws 800ma at 12v.
If I place a 1 amp automotive fuse on the hot side of the supply will this protect is from getting to hot if someone then uses a higher voltage (say 24v) by mistake and it draws say 1.5 amps.
Just trying to thinks safety!!
The fuse would then blow right, its drawing 1.5amps (1 amp fuse)???
