Fuse blown indicaor
Discussion in 'General Electronics Chat' started by SaravanaA, Jan 7, 2016.
  1. SaravanaA
    Dec 30, 2015
    15
    Hi
    how to design 230v fuse blown indicator circuit ?????
    please give proper circuit diagram
  2. MaxHeadRoom
    Jul 18, 2013
    10,864
    2,525
    Neon lamp!
    You can buy the fuse carriers complete with neon installed.
    Max.
  3. SaravanaA
    Dec 30, 2015
    15
    power source is generator .....in automotive purpose
  4. crutschow
    Mar 14, 2008
    13,511
    3,385
    I'm confused. :confused:
    You said it was a 230V circuit.
    absf and GopherT like this.
  5. GopherT
    Nov 23, 2012
    6,330
    4,070
    The light goes out when the fuse blows
    cmartinez, #12 and absf like this.
  6. MaxHeadRoom
    Jul 18, 2013
    10,864
    2,525
    As per posted in #2, If a neon is placed across the fuse it lights when the fuse is blown, I use this style of fuse holder in present panel building.
    Made by BussFuse.
    Max.
  7. #12
    Nov 30, 2010
    16,705
    7,358
    I've done more complicated circuits with a red/green LED, but it was just a design experiment, not an elegant method for a 230 VAC line. A UL approved neon indicator is way simpler and safer than what I did as a curiosity project.
    cmartinez likes this.
  8. Kermit2
    Feb 5, 2010
    3,854
    968
    Indication of a blown fuse at my house always included quiet and darkness. A flashlight and replacement fuse soon brightened the situation.
    What kind of 240 volt equipment are you powering that doesn't indicate it has no power and needs a secondary indicator to show it is not working?
  9. #12
    Nov 30, 2010
    16,705
    7,358
    Meh. Sometimes an idiot light is convenient. I designed 5 idiot lights in my air conditioner so it tells me whether it has a drain problem, a fan motor problem (two motors), or a Freon problem (High pressure safety-out or Low pressure safety-out).
  10. Dodgydave
    Jun 22, 2012
    5,166
    776
