Functions in C language
circuit2000
Joined Jul 6, 2006
33
In one of my exams the following question was asked:
# List the 4 types of functions in C.
Here are they referring to the 4 library functions in C namely math.h,string.h,stdio.h & stdlib.h?
Papabravo
Joined Feb 24, 2006
21,227
I don't think so, since there are more different kinds of header files than there are cross ties on the railroad tracks. I think it relates to return value and arguments.
Rich (BB code):
void function_type_1(void)  //No arguments, No return value
void function_type_2(char)  //1 argument, No return value
char function_type_3(void)  //No arguments, Returns a char
char function_type_4(char)  //1 argument, Returns a char
Each of these function types would cause a compiler to generate different prologues and epilogs. If you don't know what those are, they are the instructions just before and just after a function call.
Dave
Joined Nov 17, 2003
6,969
To be fair that question is as ambiguous as can be. Depending on your interpretation, one could argue there are only two types of function in C: user defined functions (i.e. those that you write) and library functions. Then the type can be sub-divided further in the way Papabravo has specified above, and in a similar way you have in your OP.
If I received that question in an exam, I would probably be pretty miffed unless the lecturer had told me explicitly during the course that the 4 types of function in C are A).... B).... C).... and D)....
Dave
