I need to solve this problem:
Question:
For this block diagram of a PV system below I need to describe the main functions of the inverter. In your answer I have to discuss the requirements for the inverters used in PV systems.
I've already found requirements for the inverters used in PV systems.
Power electronics (inverter):
- Power conversion and conditioning
- Undervoltage/overvoltage
- Under frequency/over frequency
- Overcurrent
- Synchronization
- Ground fault overvoltage
- Active anti-island function
But could you help me with describing the main functions of the inverter and describing requirements above?
Question:
- Overcurrent
- Synchronization
