Function with no output for a given set of vales
Discussion in 'Homework Help' started by Code, Dec 4, 2005.
  1. Code
    Nov 29, 2005
    Hey
    if function has no output for encoded numbers above a given number is there anything special when representing the algebraic expression?
    Example "1 if even, 0 otherwise.No output above 2."
    | X Y
    0 .. | 1
    1 .. | 0
    2 .. | 1
    3 .. | x
    So is this as simple as
    Function = X'Y' + XY'
    or is there anything else?
    Thank.
  2. aac
    Jun 13, 2005
    35
    Yes, having combinations that are unspecified can allow some simplification. If there in nothing greater than 2, we can assign anything we want for the other numbers. this is usually refered to as a don't care. Since we dont care, we would assign 3 to be 0. This would let the function simplify to "Function = Y'.
