Function realisation using MUX,DEC and
xxxyyy
Joined Oct 7, 2011
34
Problem:
Realise function F(A,B,C,D)= A*C*D + A*B*D + A*C*D + A*B*D using DEC 3/8, MUX 8/1 and required number of Nor gates. (underlined variables are complements)
I know how to realise it using only MUX 8/1,but I really have no idea how to use MUX in combination with DEC and NOR to realise function above... Can someone help me?
Yako
Joined Nov 24, 2011
245
When you formally study digital electronics you are told things like: with an OR any 1 gives a 1, and with a NOR -- any 1 gives a 0.
Georacer
Joined Nov 25, 2009
5,182
Supposing that you can use the NOR gates to implement a SoP form with the DeMUX and you have two DeMUXs, consider the following:
Separate the function into two parts, the one that factorizes with A and the other with A'. Construct each sub-function with a DeMUX. Use the MUX with selector A to select between the outputs of the two functions. A 2/1 MUX would be sufficient here.
Check if that's ok and come back to tell us.
