Function Pointer
Discussion in 'Programmer's Corner' started by aamirali, Nov 20, 2012.
  1. aamirali
    Feb 2, 2012
    415
    Function Pointer
    Code ( (Unknown Language)):
    1.
    2. #define IAP_LOCATION 0x1FFF1FF1
    3. typedef void (*IAP) (   unsigned int command[],
    4.                         unsigned int result[] );
    5. static const IAP iap_entry = (IAP) IAP_LOCATION;
    6.
    7. void writeEEPROM( uint16_t* eeAddress, uint8_t* buffAddress, uint32_t byteCount )
    8. {
    9.     unsigned int command[5], result[4];
    10.
    11.     command[0] = 61;
    12.     command[1] = (uint32_t) eeAddress;
    13.     command[2] = (uint32_t) buffAddress;
    14.     command[3] = byteCount;
    15.     command[4] = 375;
    16.
    17.     /* Invoke IAP call...*/
    18.     iap_entry(command, result);
    19.     if (0 != result[0])
    20.     {
    21.         //Trap error
    22.         while(1);
    23.     }
    24.     return;
    25. }
    26.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    is there a question?
  3. aamirali
    Feb 2, 2012
    415
    I couldn't complete my query,sry 4 dat.
    What does below line do in above code:
  4. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Ohhhhhhh. mobile device??
    (IAP) is a typecast. IAP location is a numerical value.
    "static const" is very compiler specific.
    But normally const means the particle will be placed in ROM.
  5. spinnaker
    Oct 29, 2009
    5,076
    1,176
    No one is going to be able to help you if you can't give full details of your issue. If you are having trouble with English then perhaps you should try and find a friend or co worker help you to write your question.
  6. takao21203
    Apr 28, 2012
    3,578
    463
    static const - let's think of that as ROM for the time being.
    so it is
    rom IAP iap_entry = .....
    this is misleading, as IAP and iap_entry can be confused for each other by people who don't know much C.
    It means, an IAP structure named iap_entry is declared, and placed in ROM.
    it is also assigned a value: IAP_LOCATION (which is simply numeric).
    This value is casted into IAP using a typecast: (IAP).
    I hope this helps.
