Function Generator
Discussion in 'General Electronics Chat' started by Tree1, Oct 6, 2011.
  1. Tree1
    Nov 30, 2010
    46
    Topic: Function Generator; Pulse Waveforms
    Why does a pulse waveform with parameters 2.5Vpp and 1.25VDC offset give you a 5V pulse? Why can't 5.0Vpp give you a 5V pulse ? Thank you.
  2. someonesdad
    Jul 7, 2009
    1,585
    141
    I would guess you're making the rather common mistake of operating your function generator into a high impedance. Your function generator probably has an output impedance of 50 ohms, so you should terminate the output with a 50 ohm resistance; then the output amplitude will read correctly. Some function generators let you tell them whether you're operating into a 50 ohm load or a high impedance load and thus let you have correct amplitude settings for either case (quite convenient and easy to do in firmware, as no hardware has to change).
    Tree1 likes this.
  3. Tree1
    Nov 30, 2010
    46
    Someonesdad, Thank you for assistance. Yes, that seems to be the problem. I red something similar on a website and I really wanted to confirm. Thank you for confirming the issue. I'll fix this. Have a great day.
