Function generator
Discussion in 'The Projects Forum' started by yogesh1990, Oct 26, 2010.
  1. yogesh1990
    Oct 5, 2010
    11
    Hii... Everyone.. I m making an Op Amp based Function generator for my project ....It generates Triangular, Sine, Square waves. The Triangular wave is the Base ..Then I apply a Waveshaper to it to get sine ...aand Differentiate triangular wave to get Square Wave
    My Query is this ... How does the Circuit perform as a Triangular wave oscillator.. I just don't get the logic . Pl.. help !.. someone... I have to submit the report on 31st !!!
  2. Kermit2
    Feb 5, 2010
    3,852
    968
    It shows the voltage 'ramp' that is a function of the RC time constant in that generator. Different freq are selected by varying the values of R and C in the circuit.
    It shows a time related output voltage equivalent to the charging of the capacitor. The charging rate it tracks should only be a small portion of the full charging time of the cap, so it will appear to be a linear function.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
  5. yogesh1990
    Oct 5, 2010
    11
    Thank you so much Both of you !!!! Really appreciate it
