function generator
Discussion in 'Off-Topic' started by samjesse, Feb 21, 2010.
  1. samjesse
    Thread Starter Active Member
    Sep 14, 2008
    202
    Hi
    Does a variac do anything a good function generator does not?
    i.e. vary AC from 0 to 260v...etc
    thx
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    How much current can your "good" function generator supply? Variacs can supply in excess of 10 A.
    John
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    A variac is just an adjustable transformer.
    It will only work on the frequency that is supplied at the input.
    http://en.wikipedia.org/wiki/Autotransformer
    A function generator can produce a lot of wave forms and frequencies at low voltage ( upto 20 Vpp most times ).
    Greetings,
    Bertus
  4. samjesse
    Sep 14, 2008
    202
    A function generator controlling a power transistor can take care of the 10A.
    what about the AC signal. would a variac give a cleaner AC wave ones.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    You are mixing apples and oranges. A variac is a power device, meant to connect to house current. A function generator is a universal signal generator, not meant to provide power.
    A variac output is as clean as the input.
  6. jpanhalt
    Jan 18, 2008
    5,699
    909
    The original question seems to be evolving. In other words, given enough additional parts, there is nothing that a Variac can do that a 5 HP gasoline engine cannot do.
    A Variac is not a signal generator, but a signal generator with enough additional parts can provide the same functions as a Variac. Why do that though?
    John
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Never did like the taste of orange pie.
  8. retched
    Dec 5, 2009
    5,201
    313
    You want a sine-wave generator, then a transformer to boost the signal.
    The cleanliness of the signal has a lot to do with the quality of the components and the architecture of the project. Proper decoupling, isolation..
