Function generator transistor testing
Discussion in 'General Electronics Chat' started by Nubz, Apr 28, 2015.
  1. Nubz
    Apr 12, 2015
    8
    My function generator outputs around 10mA @ 4.7V max , I would like to drive some transistors some bipolar and some mosfets with it for testing purposes, what is the best way to amplify the signal. Using single transistor or darlington or maby something else? In other words I need more current , and more voltage for mosfets.
  2. ScottWang
    Aug 23, 2012
    4,925
    777
    Using totem pole bjt driver, you can use +V, 0V or +V, 0V, -V.
    You can also add a pot to adjust the input voltage level.
    You can provide the voltage for totem pole bjt driver as +6V, 0V or +6V, 0V, -6V, or +9V, 0V, or +9V, 0V, -9V.
  3. crutschow
    Mar 14, 2008
    13,482
    3,370
    What are the waveforms and their maximum frequency?
  4. Nubz
    Apr 12, 2015
    8
    Interesting, what transistors should I use for such a low current (10mA). I understand I need a pnp and an npn bjt.
    Square, sine and dc is what I am interested in, max frequency up to 5Mhz
  5. ScottWang
    Aug 23, 2012
    4,925
    777
    2N3904(NPN) and 2N3906(PNP).
  6. upand_at_them
    May 15, 2010
    246
    29
    So you're going to make him deal with crossover distortion?
  7. ScottWang
    Aug 23, 2012
    4,925
    777
    I just thought the TS might be want to using it with square wave to do the test, if he doesn't then maybe he can using LM380 or LM386.
  8. upand_at_them
    May 15, 2010
    246
    29
    How about an LM6181 or LM7171?
  9. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    I've seen some op-amp designs that directly drive a complementary-symetry pair with the bases tied together, crossover seems adequately reduced by including the transistor pair in the NFB loop to make an over all voltage follower.
    The clever bit is finding an op-amp with bandwidth to match the function generator.
  10. ScottWang
    Aug 23, 2012
    4,925
    777
    They are designed for high frequency as video amp and higher load as 50-Ω or 75-Ω, if the function generator is a AF as 20Hz ~20KHz then these two chips is not a appropriate amp.
    LM386 - LM386 Low Voltage Audio Power Amplifier.
    LM6181 - LM6181 100 mA, 100 MHz Current Feedback Amplifier.
    LM7171 - LM7171 Very High Speed, High Output Current, Voltage Feedback Amplifier.
  11. ian field
    Oct 27, 2012
    4,447
    791
    The LM386 has been widely dubbed; "The cockroach of audio amplifiers" - they're fairly noisy.
  12. Nubz
    Apr 12, 2015
    8
    Thank you all, I am grateful for the much needed advice. :D
  13. ScottWang
    Aug 23, 2012
    4,925
    777
    Since the cockroach can be live longer ... :D
    If using it for audio sine wave with 4.7 Vin then it's ok, not use it as 0.2V.
  14. ScottWang
    Aug 23, 2012
    4,925
    777
    If you using the amplifier to test the bjt and mosfet as switch function, then maybe you just need +V, 0V totem pole bjt driver, the +V as 12V, 18V, 24V.
