Function Generator Output Boost
Discussion in 'General Electronics Chat' started by rcbuck, Nov 11, 2009.
  1. rcbuck
    Nov 10, 2009
    9
    I have built a function generator using the XR-2206. I am getting a little over 2 volts output for the sine wave. The circuit is running on +/- 9V supplies. What would be the best way to increase the output to around 5 volts and drive a 50 ohm load? That would be around 1/2 watt output. Possibly a voltage amplifier followed by an emitter follower?
    Ray
  2. KL7AJ
    Nov 4, 2008
    2,043
    292
    Check out video distribution amps.
    http://www.opamplabs.com/407g.htm
    You can probably build one cheaper, but this will allow you to spend your time doing something more productive. :)
    eric
  3. Ron H
    Apr 14, 2005
    7,050
    657
    He could have bought a function generator if he wanted to be more productive.:D
  4. rcbuck
    Nov 10, 2009
    9
    How true, but what is the fun in being productive? I will probably do something like is shown in National Semiconductor AN-272.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You might consider something like a video opamp, like an LM6171.
    Avnet Express sells those in a SOIC-8 (surface mount) package for about $1.75. They're out of the 8-DIP packages until December.
    You could also use a high-speed low-power opamp with a gain of 2.5, and back it up with a power buffer like an LT1010; it'll source/sink up to 150mA.
  6. rcbuck
    Nov 10, 2009
    9
    I did some research after my last post and decided to try the LM6181 since I can run it on +/-15V supplies. Order has already been placed with DigiKey.
  7. magnetman12003
    May 10, 2008
    31
    I will have a HP 3011A Function generator refurbished soon. If interested I can sell it cheaper than any listed on Ebay. I bought this unit - It came DOA and I was told to keep it. They sent me free another replacement generator that did work.
    I decided to repair the DOA unit. Replaced all the power supply components and installed a modern on/off Neon lamp instead of the old flickering NE-2H. I did not check calibration.
    This generator is capable of sending 0 -30 volts peak to peak to its output.
    If anyones interested let me know what its worth to you after you check whats for sale on Ebay.
    Tom
  8. KL7AJ
    Nov 4, 2008
    2,043
    292
    I'm jaded about a few things. Since I worked in TV broadcasting, video DA's tend to reproduce like coat hangers in a neglected closet. :) I've never had to pay for any of these!
    Incidentally, Op-Amp Labs makes some fantastic modules for this sort of thing....almost anything from DC to Daylight. Most of their stuff is in OCTAL socket form...just add power!
    Eric
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If it were going to be higher frequency and higher gain, I would've suggested Mini Circuits. Great stuff for the price.
