Function Generator Amplification
Discussion in 'The Projects Forum' started by Wajhi, Feb 28, 2013.
  1. Wajhi
    Oct 17, 2011
    14
    Function Generator Output Amplification.
    I want to take function generator as input (45 MHtz max, square and sine both waveforms) and the amplifier should be able to handle it at input and output. plus provide output current till around 1.6 amps . the lower the noise the better. money isnt an issue
    I need circuit, or schematic or name of op-amp i can use...i was thinking of using http://www.ti.com/product/opa1664 as starting point...and I dont have alot of days to design it...any help would be much appreciated!!
    and if you know any basic amp designing books/pdf/course that would be great too
  2. w2aew
    Member
    Jan 3, 2012
    219
    64
    A lot more information is needed.
    What input voltage range?
    What are the -Peak and +Peak voltages for input and output?
    What supplies are available?
    What output voltage range? (telling us current alone doesn't give enough info).
    You likely will not find a monolythic opamp that can source/sink anything near 1.6A, particularly with that kind of speed, so you'll have to design something that includes some kind of a power amplifier, which won't be trivial at these power levels. Assuming 1.6A is the rms current into a 50ohm load, that's 128W of output power at HF-VHF frequencies. Including harmonics of the squarewave at 45MHz, then the BW of the amp has to extend into the low UHF frequency range. Certainly not a trivial task, and not something you're likely to find in a forum post.
  3. Wajhi
    Oct 17, 2011
    14
    well the input WOULD BE THIS FUNCTION GENERATOR : http://www.finaltest.com.mx/ProductDetails.asp?ProductCode=AWG5004B
    p.s i can buy any function generator, no issue
    the max output current can be altered to 1 amps if that helps
    no limit of supplies either..all lab supplies
  4. w2aew
    Member
    Jan 3, 2012
    219
    64
    I know that AWG very well, I work for Tek.
    What is the load that you intend to drive?
  5. Wajhi
    Oct 17, 2011
    14
    the load is a micro coil..with inductance in nH....also resistance is extreamly low
  6. Wajhi
    Oct 17, 2011
    14
    guys really need your help
  7. #12
    Nov 30, 2010
    16,705
    7,355
    Over 3 gigahertz of bandwidth? Over 100 watts? and you want it when?
    ROFL!
  8. Wajhi
    Oct 17, 2011
    14
    What....how did u reach over 3 Ghz of BW and over 100 Watts?
  9. #12
    Nov 30, 2010
    16,705
    7,355
    This says, "over 100 watts".
  10. #12
    Nov 30, 2010
    16,705
    7,355
    and this says, "300 picoseconds rise time".
    Caracteristicas
    Arbitrary Waveform Generator
    AWG5000B Series (AWG5014B • AWG5012B • AWG5004B • AWG5002B)
    Features & Benefits
    • 370 MHz Effective RF Frequency Output
    • 1.2 Gs/s and 600 MS/s Models
    • 14 bit Vertical Resolution
    • 2 or 4 Arbitrary Waveform Differential / Single-ended Outputs
      • Up to 4.5 Vp-p Single-ended and 9 Vp-p at Differential Output into 50 Ω
      • 0.95 ns Tr/Tf (10 - 90%) at 0.6 Vp-p
      • +/– 5 ns Range (50 ps Resolution) Inter Channel Skew Control
      • SFDR: 80 dBc (1 MHz), 64 dBc (10 MHz)
    • 4 or 8 Variable Level Marker Outputs
      • Up to 3.7 Vp-p Single-ended Output into 50 Ω
      • 300 ps Tr/Tf (20 - 80%) at 0 to 1 V
      • Up to 1 ns Range (50 ps Resolution) Delay Control
    • 28 bits ch1/ch2 Variable Level Digital Data Output
  11. thatoneguy
    Feb 19, 2009
    6,357
    718
    I'll just throw out a guess here...
    Wireless power?
  12. Wajhi
    Oct 17, 2011
    14
    ok so help me....the current requirement has been dropped to 1 Amp and also if I will be working with 45Mhtz, then wont rise time be a problem? I am just trying to learn here
  13. Wajhi
    Oct 17, 2011
    14
    ....no ...not wireless power
  14. Wajhi
    Oct 17, 2011
    14
    @w2aew
    @thatoneguy Look all i really need is 1 amps and for the amplifier to work on 45MHtz..nothing else///there are 3 function generators available. I just need a schematic so I can build the amplifier
    Function generator :
    Agilent 33220A
    Hameg HM8150
    Also can this amplification be achieved using this piezo amp:
    TREK PZD350??
  15. thatoneguy
    Feb 19, 2009
    6,357
    718
  16. Wajhi
    Oct 17, 2011
    14
    nothing that I can build ?? ..a simple amplifier capable of outputting 45 Mhtz at variable 0.5-1 amp current..and a function gen. at input...!??!
