Hey Guys I'm new here, and I have a project, a Function Generator...
and I need help finding an IC op-amp to use for the high frequency range of 3Mhz what Type of IC Op-amp should I use, the LM741 isn't Oscillating at High Frequency so, I need to find something else,
and Also i'm using a High Pass Filter Phase Shift Oscillator 3 RC networks
and Also if You could help me Find the value of Resistance as Well, and what value of Rg and Rf i should Use to produce the range of 0.03hz to 3hz..
