Fun things to do with an oscilloscope
Discussion in 'General Electronics Chat' started by tom66, Aug 28, 2010.
  1. tom66
    Thread Starter Senior Member
    May 9, 2009
    2,613
    214
    If anyone has a scope, post something fun you can do with it (this is related to my oscillator challenge, which, by the way, nobody has yet beaten.)
    In this case I have a digitising oscilloscope operating on 50 Hz mains. If I amplify the noise signature from the oscilloscope (about 20x) to get 250µV/div (4 screens, 2 divs per screen), I can see the oscilloscope's screen refresh rate - 60 Hz. The noise on this scope is remarkably low for a CRT based digital oscilloscope (375µVp-p). The trigger is sensitive enough to pick up the 80µV or so pulses in the analog side. See the attached image. I know this is the screen refresh rate and not the mains ripple in the power supply/voltage references because the scope is running on 50 Hz mains (maybe next time I will try and extract the mains ripple.)
    I wanted to get XY mode working on it, but like many digital oscilloscopes XY mode doesn't work too well; the bandwidth is too limited. Lissajous figures are only possible up to a few kHz. My college has analog scopes in their labs, so it will be interesting to see how my use of the digital scopes' menus translates to all the dials - hopefully well...
    Anybody else have any tricks?
