Fun little brain teaser
Discussion in 'General Electronics Chat' started by KL7AJ, Sep 22, 2015.
  1. KL7AJ
    Thread Starter AAC Fanatic!
    Nov 4, 2008
    2,047
    295
    I ran across this ages ago, and I present it to each new electronics class as an exercise.
    You have a black box with four leads coming out of it. You apply a voltage (ac or dc) to any two adjacent leads. The two remaining leads output precisely 1/4 of the applied voltage. What is in the box?
    Eric
    blocco a spirale and AnalogKid like this.
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    a wheatstone bridge with an inverted side? Like this:
    the 12V source represents your applied voltage, and points C & D represent your output leads. Potential difference between C & D is 4V (1/3 applied voltage in this case).
  3. KJ6EAD
    Apr 30, 2011
    1,426
    363
    I agree in principal but don't the resistors have to hold the ratio X:3X to satisfy the 1/4 voltage requirement?
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    The values can be changed to make it hold a 1/4 voltage when voltage is applied from opposite corners, but when it is applied on the same side, it no longer works. So I proved myself wrong. I'll think about more tomorrow. Good night.
  5. blocco a spirale
    Jun 18, 2008
    1,461
    370
    Here's what I think it is:
    cmartinez and strantor like this.
  6. strantor
    Oct 3, 2010
    4,302
    1,989
    Nice! And you even made it look like a box!
  7. KL7AJ
    Nov 4, 2008
    2,047
    295
    Free hint: It can be done with just 5 resistors
  8. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,696
    1,297
    If the four leads are in a row, does the outside pair constitute an adjacent pair as if the four leads were in a box?
    Or does four-in-a-row intentionally have one fewer possible connection?
    ak
  9. blocco a spirale
    Jun 18, 2008
    1,461
    370
    Version 02:
  10. GopherT
    Nov 23, 2012
    6,314
    4,033
    So, I assume "Blocco a Spirale" translates to, "Master of Voltage Dividers"
    PS: I know it is a "spiral notepad" but I like my translation better for today.
  11. blocco a spirale
    Jun 18, 2008
    1,461
    370
    I'll settle for "Master of guesswork that just happened to lead to a quick solution but may not be so lucky next time" :)
    GopherT likes this.
  12. KL7AJ
    Nov 4, 2008
    2,047
    295
    Here ya go.
  13. blocco a spirale
    Jun 18, 2008
    1,461
    370
    Well, that makes sense o_O
