Fun activities for teaching basics of electronics
Discussion in 'General Electronics Chat' started by mcgyvr, Sep 25, 2014.
  1. mcgyvr
    Thread Starter AAC Fanatic!
    Oct 15, 2009
    4,791
    976
    Looking for some "fun" and interactive things to do while teaching a class in the basics of electronics.
    I want just some fun visual things I can show.. This is for the assembly staff at my work so nothing fancy just the absolute basics of electronics.. I really don't want to go past just a battery/lightbulb/switch level.. But want something "fun" thats still kindergarten level stuff..
    We use nothing more than resistors/leds and relays and maybe a few capacitors/transistors in our products but thats the extent of the components we use.
    Like touching steel wool to a battery type stuff..
  2. wayneh
    Sep 9, 2010
    12,386
    3,244
    The visual aids should support the concepts you are teaching, to literally help the student picture the concept. Helps the memory.
    One common misconception about electricity is that "voltage" is some sort of of measure of power. Reinforcing the notion that a circuit must be COMPLETE, and that current must flow, would be a useful point to emphasize with a demo. Blow something up with low voltage and high current (maybe a rocket igniter?, or an old flash bulb?), and contrast it by letting something at high voltage, little or no current, remain unscathed.
    I think most people can grasp what a capacitor is, since it resembles a battery. Resistors, LEDs and even relays are pretty easy to make sense of. But good luck explaining transistors. Some visual demonstration would be great, maybe a pneumatic valve? (small air flow controls a large valve)
    mcgyvr likes this.
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    when you get to radio, a transistor radio will pickup the buzzing from a small buzzer connected to a battery. make sure it is the coil and pointgs type buzzer. a short piece of wire connected to the buzzer will let you pick it up around a room.
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
    Thats exactly why I wanted these visuals.. We aren't trying to make EE's.. Just have them understand why they are doing what they are doing at the test stand..
    I can talk them to death (or to sleep) but its the simple fun stuff that will help them learn and remember it..
    We just reinforced the rule again that all jewelry must be removed at the test stands and they didn't understand why.. So one of my experiments will be to show a circuit being completed with my wedding ring.. (or similar)..
    My boss and I already decided that using a LARGE capacitor bank to explode a watermelon was a bit too much for this class.. Cool but a bit of an overkill :)
    They have already learned sort of about the voltage/power you are speaking of.. We do hipot testing and they are initially scared to death of it seeing the 1100V on the testers analog meter and will stay 10 feet away at first.. Thats when I give them a bit of a talk about the "current that kills..not voltage" basic explanation.. Then of course (because I'm a bit crazy but it works) I've actually tripped it on myself before just to show I'm still alive after..
    I like the pneumatic valve deal.. We have plenty of them around.. Great way to show a transistor..
    Thanks so far.. please keep them coming if you have any.. :)
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    how about winding some wire on a nail and show them how an electromagnet works?
    wind a little wire around a compas and show how the magnetic field moves it around?
    mcgyvr likes this.
  6. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  7. #12
    Nov 30, 2010
    16,690
    7,330
    Here are a couple of my favorites, a finger hum switch and a Cds photocell switch.
    mcgyvr likes this.
  8. sirch2
    Jan 21, 2013
    1,008
    351
    How about a Crystal radio, variable capacitor, diode, coil wound on a cardboard tube and an earphone.
  9. mcgyvr
    Oct 15, 2009
    4,791
    976
    Thats a little bit advanced than I wanted to take it.. But still a great suggestion.
  10. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  11. mcgyvr
    Oct 15, 2009
    4,791
    976
    Anyone got a good experiment to show the importance of not missing a solder connection or not tightening a bolted connection in an electrical circuit..
    Something with arcing
  12. alfacliff
    Dec 13, 2013
    2,449
    428
    a bolted connection to a battery a little loose?
  13. mcgyvr
    Oct 15, 2009
    4,791
    976
    Yes but what "fun" could I have with that?
  14. ISB123
    May 21, 2014
    1,240
    531
    Take a small dc motor with some kind of stick on the shaft ,on lose connection dc motors will speed up and down.
  15. wayneh
    Sep 9, 2010
    12,386
    3,244
    A car that won't start because of a loose ground strap?
  16. KL7AJ
    Nov 4, 2008
    2,047
    295
    I like using plumbing to demonstrate Ohm's Law (and even Kirchhoff's current law). Demonstrate how the flow through a fatter pipe is greater for the same amount of pressure. Clear neoprene hose with colored water makes it less boring. :)
  17. wayneh
    Sep 9, 2010
    12,386
    3,244
    There are a lot of demonstrations like this one on YouTube. I don't know how you'd tie it to your lesson plan, but it sure gets your attention.
