I have a microcontroller interfacing with an SD card. I want to be able to remove the power supply from the SD card when the device goes into "sleep" mode. I use the following schematic to connect/disconnet the sd card power supply:
When pulling the base to GND the sd card turns on. But when i try to turn the transistor off, the collector only drops to 2.8V and never disconnects the SD card from the power supply(VCC).
I dont understand what is wrong with this circuit, when removing the SD card and connecting a load to the transistor collector pin the transistor works as it's supposed to do so it looks like the SD card is causing this behavior. Any advice?
Regards,
Sisco
Regards,
Sisco
