Fully Controlled Bridge Rectifier
Discussion in 'General Electronics Chat' started by neilio2j, Nov 19, 2007.
  1. neilio2j
    Nov 19, 2007
    hi im doing a project at college and im trying to find out how to derive the equations for:
    a) load voltage
    b)supply current
    for a circuit with and without a flywheel diode connected
    can anyone help? im totally stumped with this
  2. cumesoftware
    Apr 27, 2007
    1,330
    11
    What is a flywheel diode?
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Can you supply us with a circuit diagram to give us a clear picture of what you are working with?
    hgmjr
  4. neilio2j
    Nov 19, 2007
    A flywheel diode is often required, because when the current through an inductive load is suddenly broken, a back EMF will build up as the magnetic field breaks down, and if there is no path for the current, a high voltage builds up. The high voltage can damage a transistor or cause arcing in a switch. The flywheel diode is connected in reverse across the load, and provides a path for the current so the magnetic field and current can safely decline.
    there is a copy of the circuit i am working with, sorry i dont know how to post images
    http://services.eng.uts.edu.au/~venkat/pe_html/ch04s2/mathsim/cirdia5.gif
    when the flywheel diode is attached it will be connected in parallel across the inductor and resistor
    thanks for your help guys
