Full Wave Rectifier
Discussion in 'Homework Help' started by ac_dc_1, Jan 30, 2013.
  1. ac_dc_1
    Jan 27, 2013
    74
    I am trying to analize this rectifier.I want to determine the expressions of the ouputs and the gain of both Amps and of the montage
    VO1= 0V if Vi>0V
    For the second OpAmp
    Vo2=-R5/R3 Vout 1 - (-R5/R4)Vout for Vin<0 V
    and Vo2=-R5/R4*Vin if Vin>0 V
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    The circuit works very well when the opamps have a positive and negative power supply.
    The first opamp circuit produces only the negative parts of the input. Its level is doubled by the second opamp and added to the input signal then some of the positive cancels the negative and produces full-wave rectification.
  3. ac_dc_1
    Jan 27, 2013
    74
    So the second opamp has a gain of 2,rigth?
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The second opamp has a gain of 20k/10k (R5/R3=2) for the half-wave rectified signal from the first opamp and it has a gain of 20k/20k (R5/R4=1) for the input signal.
    Then when the input signal goes negative one amount the output of the second opamp goes positive two amounts which cancels the negative leaving a signal level of positive one.
  5. ac_dc_1
    Jan 27, 2013
    74
    So in conclusion Vo=-vi if Vi<0 and Vo=Vi if Vi>0
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    Work out what the voltages would be if the input was +5VDC
    Do the same, but with an input of -5VDC
    From there, you'll have a good understanding of how the circuit works.
