Full wave rectifier
Discussion in 'Homework Help' started by skiddman, Nov 12, 2012.
  1. skiddman
    Nov 7, 2012
    26
    what would happen if one of the diodes in the rectifier was installed backwards? Include an explanation of the waveforms that would be observed and/or the voltages you would expect to measure across the load.
  2. skiddman
    Nov 7, 2012
    26
    V Primary-120 vrms
    V Sec-28.3 Vrms
    RL-4.7K
  3. vk6zgo
    Jul 21, 2012
    677
    85
    Draw a rectifier with all the diodes the right way round.
    (a)Trace the currents for each 1/2 cycle,& determine the voltage across RL.
    As the load is resistive (no filtering),what can you assume about the waveshape & peak amplitude of this voltage?
    What is it's rms value?
    What is its average value?
    (b)
    Reverse one of the diodes,& again trace the currents,as before.
    What has now happened to the waveshape of the voltage across RL?
    What is its peak value?
    If you use this method you should be able to determine all the information wanted,plus cement a few concepts in your mind.
