Full wave rectifier with
Discussion in 'Homework Help' started by lilly, Oct 10, 2013.
  1. lilly
    Oct 10, 2013
    A DC voltage source is required to deliver an average voltage of 20V to a load. Calculate the amplitude of the AC supply voltage if the ripple voltage of the full-wave diode rectifier's output voltage is equal to 0.2V (peak-peak) and the forward voltage drop across each diode is equal to 0.6V.
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    1) Still can't see image of circuit.
    2) Be sure that image of circuit includes image of YOUR best effort to solve YOUR homework problem.
    We won't work your homework for you. But we will take a look at what you have done and guide you in the direction of finding a solution.
