Full wave rectifier with R load
Discussion in 'Homework Help' started by notoriusjt2, Oct 4, 2010.
  1. notoriusjt2
    Feb 4, 2010
    209
    A single-phase full-wave bridge rectifier has a resistive load of 18ohms and an ac source of 120V rms. Determine the average power in the load.
    these average power questions are killing me....
    Vo=((2)(120)(1.414))/pi = 108v
    Io= Vm/R = 108/18 = 6A
    P=108*6=648w
    so what step am i forgetting to do here... i am never taking an electronics/math class online again.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    I think that you need to find RMS voltage and current.
  3. notoriusjt2
    Feb 4, 2010
    209
    so
    Vrms=108/1.414=76.37
    Irms=6/1.414=4.24
    P=76.37*4.24=324w
    would this be correct?
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    P_{avg}=\left\langle \frac{V^2}{R} \right\rangle \\ <br />
=\frac{\langle V^2 \rangle}{R}\\<br />
=\frac{V_{rms}^2}{R} \\<br />
where\ \langle\ \rangle\ \text{is the time mean}
    Your answer is wrong, because Vrms is not connected to the average voltage with the relation you wrote. The Vrms of the rectified waveform is the same as the Vrms of the initial sine wave. Do the math and it will become apparent. Use the default RMS calculation formula.
    Is that clear?
  5. Jony130
    Feb 17, 2009
    3,993
    1,116
    Hehe, No.
    Maybe you should read the question again.
    "A single-phase full-wave bridge rectifier has a resistive load of 18ohms and an ac source of 120V rms. Determine the average power in the load."
  6. notoriusjt2
    Feb 4, 2010
    209
    yea that helps, but what do you mean when you say time mean?
    so if Pavg=(V^2rms)/R
    then
    Pavg=(120^2)/18
    Pavg=800w
    is that what you mean?
  7. Georacer
    Nov 25, 2009
    5,151
    1,266
    Time mean is just the mean of a value over a time period, mean for short. Don't bother about it.
    Other than that, your answer seems correct.
