full wave rectifier with PWL diode
Discussion in 'Homework Help' started by jut, Sep 15, 2009.
  1. jut
    Thread Starter Senior Member
    Aug 25, 2007
    224
    Each diode is modeled as a piece-wise linear device with the following parameters:
    Vd = 0.7
    Rd = 26Ω
    This means an ideal diode in series with a 0.7 voltage source in series with 26 ohm resistor, right?
    Task:
    a) Sketch Vs and Vo as a function of time.
    b) Calculate the ripple voltage of O v and determine what percentage it is of the peak output voltage.
  2. mik3
    Feb 4, 2008
    4,846
    63
    For the first replace the diodes with their equivalent circuit and use a simulation software to sketch it for you.
    For the second you will need a bit of math. :p
    To an approximation:
    Vodc=Vpeak/[1+1/(4fCR)]
    Vripple=Vdc/(2fCR)
    f=mains frequency
