Full wave rectifier efficiency
Discussion in 'Homework Help' started by Manoj Sahu, Oct 6, 2014.
  1. Manoj Sahu
    Sep 29, 2014
    8
    How to calculate the efficiency of full wave rectifier? Also, prove that efficiency of Full wave rectifier is 81.2%
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Write the expressions for DC power out and AC Power In. The ratio of those two expression will be the efficiency, just like in all the other cases where you have Power Out < Power IN
  3. crutschow
    Mar 14, 2008
    13,502
    3,376
    The efficiency depends upon the diode drops at the load current and the AC voltage value . The efficiency is not a fixed value independent of these variables.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Power Out and Power In can be measured or theoretical. Power out definitely depends on the diode drops.
  5. wayneh
    Sep 9, 2010
    12,391
    3,246
    I can prove that it is almost NEVER that exact value, except in a very specific set of circumstances, which you have not provided us.
