Also 120Hz with the filter capacitors, if there is any load.120 Hz without the filter capacitors....
You are getting into semantics and I am not sure I are with definitions. AC is any non-DC waveform (including your "pulsing DC", square wave, rectangular e wave, triangle, sweep, ...) and therefore, any "waveform". AC does not have to be a sine wave, it does not have to oscillate +/- ground (it can have a DC offset and commonly does. AC is any signal that is not steady DC. Steady DC is rare other than battery with only a resistive load and no outside interference.It should be observed that the output of a bridge rectifier is not alternating (AC) and therefore does not strictly have a frequency in the AC sense.
However, it is not steady DC either. It is in fact pulsing DC or unidirectional current with a pulse repetition time equal to the pulse length of .00833... seconds - which equates to a pulse repetition rate of 120 pulses per second.
The graph of the output is not a continuous function.
+1 on that.I'm with you on that. The term is alternating current, not alternating voltage. The thing that alternates is the direction of the current, not the magnitude.
by Duane Benson
by Duane Benson
