Is the amplitude of a full volume pure tone from a laptop ±1v or ±1.5v?
I have an audio to DC envelope circuit and want to spec. out a trim pot for the gain.
I did not say anything about 300-500 KHz I said Hz regarding AC volt measurement and DMMs. I think my fluke true RMS meter goes up to about 100Khz then measuring AC (volt)I would say that 85-155Hz is a LITTLE lower than 300KHz...
by a lot.
So then people talk you in the phone you only hear mumble-jumbleConsonants of speech range up to 14kHz. Without consonants above 3kHz then speech is just mumble-jumble.
from djsfantasiFrequency of output will be in 85-155Hz range, so a little lower than the 300-500KHz limit.
Didn't you read my attachment?So then people talk you in the phone you only hear mumble-jumble
He will never find out I swapped the electronics with a very cheap model from ChinaAnd dont let Rifaa find out you have his Fluke.
