Full Duplex Intercom
Discussion in 'The Projects Forum' started by mark63534, Jan 19, 2012.
  1. mark63534
    Nov 24, 2011
    20
    Here is the link to the schematic:
    Code ( (Unknown Language)):
    1. http://www.redcircuits.com/Page78.htm
    On the website it says that the recommended power is between 6 to 12 volts, at 200mA. Now, it's not that easy finding a power supply for that amperage. So my question is, can I simply jjust use two 9v batteries instead of using a power supply that is hard to find?
    On top of that question, I have another. How would I hookup a computer microphone to this setup (assuming that the output configuration is a 3.5mm jack) ?
  2. MrChips
    Oct 2, 2009
    12,652
    3,460
    What do you mean? Most wall warts will fit the bill. It doesn't have to be 200mA.
  3. mark63534
    Nov 24, 2011
    20
    What I'm saying is that I have a computer power supply near me (actually a molex connector used for computer power supplies) and I would like to use that. However, the rating for that power supply is 12v @ 1.5A.
    I'm pretty afraid that if I use that to power both circuits, they might just fry. Why? Because on the schematic it says to use 200mA.
    So, would they get fried or would the circuits just draw enough for operation?
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    The 200ma referred to in the schematic is how much the device needs to operate. It will only take what is needed. The battery in an automobile is capable of providing hundreds of amps. Does your car radio go up in smoke when you turn it on? No. It only take as much power as it needs as long as the supply voltage is what the unit is designed to use.
  5. MrChips
    Oct 2, 2009
    12,652
    3,460
    But before you use that 12V power supply, measure the output voltage. If it is unregulated the unloaded voltage can be 15V.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    the 200mA specification is the minimum supply rating.
    The supply can be rated for much more current and it'll be OK.
    Just don't exceed ~14v in and you should be ok.
    Use 200mA or 250mA fuses.
  7. mark63534
    Nov 24, 2011
    20
    Wow. Thank you so much. I will definitely take that into consideration when making this, and I will be checking my power supply asap.
  8. mark63534
    Nov 24, 2011
    20
    I have a second question:
    In the schematic, there is a P1 which is a 22k Log. Potentiometer. I can't find any of these ANYWHERE. So, can anyone tell me where I can get some of these?
    Or, will a 25k Log. Potentiometer suffice for the job?
    Thanks.
  9. KJ6EAD
    Apr 30, 2011
    1,426
    364
    25k will be fine. The logarithmic taper is sometimes called an audio taper.
