full bridge rectifier ckt
Discussion in 'General Electronics Chat' started by jose_007, Oct 27, 2012.
  1. jose_007
    May 3, 2011
    24
    please help me with the output waveform of this circuit...I am confused due to presence of fifth diode..
      File size:
      5.2 KB
      47
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    The fifth diode is a Light Emitting diode (LED) drawn upside down and with the light beam missing.
      File size:
      4 KB
      30
  3. jose_007
    May 3, 2011
    24
    I may be wrong,but I think it is simple diode...
    Also I am sure about orientatation of diode.
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The diode in the original circuit has reverse bias so it is doing nothing. Then the resistor in series with the diode also has no current so it also does nothing.
    jose_007 likes this.
  5. autotuner
    Oct 2, 2012
    Unless its a zener for simple regulation and just has been drawn wrong.
  6. jose_007
    May 3, 2011
    24
    @audioguru and autotuner
    that's what my first reaction was ,but when I ran it in multisim the result was a rectified wave....
    Thats what is confusing me...
  7. jose_007
    May 3, 2011
    24
    and the simulation in simulink is giving me very low voltage across resistor..
    So I don't know which simulation should I trust...
  8. autotuner
    Oct 2, 2012
    Well, if you were looking across both the diode and resistor, then there will be a rectified waveform, because the diode / resistor is basically doing nothing.
    The resistor will show a small voltage across it with any diode reverse bias leakage.
  9. jose_007
    May 3, 2011
    24
    yes,you are right....I checked the waveforms again..and it was my mistake while making oscilloscope connections....
    Thanks everyone for the help
