full-bridge converter
Discussion in 'General Electronics Chat' started by grad-student, Jan 19, 2015.
  1. grad-student
    Nov 19, 2014
    24
    I am designing a full-bridge dc-dc converter. I need to get a Vout of around 180V. I am not getting a steady Vout from this design. Any help or advice?
  2. kubeek
    Sep 20, 2005
    4,689
    806
    Why do you have ground connected to the secondary of the transformer, instead of the bottom of the load?
  3. grad-student
    Nov 19, 2014
    24
    I need a ground reference on the right hand side of the transformer. Floating circuits (with no DC path to ground) are not allowed.
  4. kubeek
    Sep 20, 2005
    4,689
    806
    Read once again what I wrote, connect the ground to the bottom of the load, not the transformer.
  5. ronv
    Nov 12, 2008
    3,403
    1,477
    Are those temperature dependent FETs? If so replace with normal ones (for spice) and see if the results are better. Then we can try to go from there.
    I think spice would be happy with meg-ohms to ground.
  6. grad-student
    Nov 19, 2014
    24
    Thanks a lot.
