Hi,The first thing I saw in the datasheet was a Vcc limit of 40V.
I thought you were working with a few hundred volts?
If so, and if you try this IC, you'll blow the lid right off of it.
You must ensure that the driver IC meets all of your requirements before you connect it, unless you enjoy seeing bright flashes and large clouds of acrid smoke, accompanied by loud "BANGs".
The 300vdc is to drive the bridge to convert to 50hz 220vac. This is obtained from the 12v battery through an inverter circuit. The SG3526 would be running from the battery and driving the bridge which would be run from the 300vdc. Both the supplies have common ground. So there is no problem with 40vdc limit.
Thanks.
