full bobbin
Discussion in 'The Projects Forum' started by vikramb, Mar 3, 2008.
  1. vikramb
    Feb 13, 2008
    7
    full bobbinnn
  2. John Luciani
    Apr 3, 2007
    477
    A transformer bobbin is an insulating frame that is used to wrap wire coils.
    Checkout --- http://www.transformerbobbin.com
    Also check the websites of companies that manufacture magnetic cores.
    (* jcl *)
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    I have come across a similar degree of confusion on another forum. Apparently, "bobbin" doesn't translate quite correctly into many languages. A bobbin is a form on which you can wind something. For example, a bobbin for thread is a small cylinder of wood or plastic on which sewing thread can be wound. In electronics, it is usually a plastic form on which wire is wound as in a transformer.
    John
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here are a couple of examples of bobbins that are designed to fit sewing machines, but many people also use them for hobbiest electronic projects:
    Plastic sewing bobbins:
    Metallic sewing bobbins:
  5. Ron H
    Apr 14, 2005
    7,050
    657
    Wikipedia can be very helpful in answering questions like these. Google is good also.:rolleyes:
  6. techroomt
    May 19, 2004
    198
    A local factory here makes bobbins of pressed powder, for the winding of inductor coils.
