Full Adder using MUX
Discussion in 'Homework Help' started by Justine1, Jul 26, 2010.
  1. Justine1
    Jul 26, 2010
    How to implement a Full Adder Circuit using a 2:1 MUX?
  2. JDT
    Feb 12, 2009
    658
    85
    Start by drawing a Truth Table for your Full adder.
    A full adder has three inputs: A and B and Carry-in. Two outputs: Sum and Carry-out.
    This cannot be implemented with only one 2:1 multiplexer. A number will be required. So not sure about "a" in your question.
    Justine1 likes this.
  3. Justine1
    Jul 26, 2010
    How can I implement A Full Adder using a 4:1 MUX?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Per post #2, draw up a truth table. Think about a multiplexer and how to make the output agree with the truth table. A full adder requires a carry bit - can a MUX do that by itself?
  5. Justine1
    Jul 26, 2010
    Can anyone please tell me how to implement a full Adder circuit using two 2:1 MUX?...:(
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This is a stone wall project for students.
    Build up to it with a half adder. make the truth table using A & B as the two bits, X as the output. Look at a MUX and see if you can't get A & B to select the X value in the truth table for the multiplexer's output.
    Do this, and all else becomes clear.
