Fuel gauge problem
Discussion in 'The Projects Forum' started by swingingbandit, Sep 18, 2010.
  1. swingingbandit
    Sep 18, 2010
    Hello to all.
    I need help with the following
    I purchased a after market instrument cluster for my motorcycle and the fuel sender is 0 to 100 ohm and the gauge is 0-520 ohm
    The instrument cluster has a common +12 volt input though can operate at 10 volt.
    The fuel sender is on the ground side
    ie. GND(-) -----Fuel sender(0-100)------Meter(0-520)-----+12v
    Is there any superstars out there that know the solution to the problem?
    Cheers
    Paul
  2. marshallf3
    Jul 26, 2010
    2,358
    201
    If it isn't working then the sensor and the gauge don't match. These are similar to the way temperature gauges work too.
    Google explains the circuits better than I can at the moment.
  3. swingingbandit
    Sep 18, 2010
    Can anyone help with this problem.
    I assume that changing the voltage would scale the meter differently but I can not do this as the + voltage only has a fluctation of +/- 2 volt
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  5. swingingbandit
    Sep 18, 2010
    Thank you
    I will order the components today. I will let you know how I got on when done
    Cheers
    Paul
