Hi All,
I am puzzled and so wanted to reach out.
I have a PCB design which uses the FTDI FT232RL as a UART-USB bridge.
I just populated 7 PCB's (same layout, batch, board house etc) and found two of them fail to enumerate the device when connected to the USB on my PC. In device manager the USB port shows Unknown USB Device (Device Descriptor Request Failed).
I suspected a damaged chip so replaced it on on of the boards (twice) taking the utmost ESD precautions. Still the same behaviour.
Its unlikely to be a driver issue as i can swap to a good board and it will enumerate just fine. The problem appears to be in hardware.
There are no shorts on open connections on the board.
Anybody had a similar experience or any suggestions?
Many thanks
Ade
Many thanks
Ade
