Discussion in 'The Projects Forum' started by zbot1, May 12, 2014.
  1. zbot1
    May 12, 2014
    Edit: sorry for the short tile, I was having problems posting (http://forum.allaboutcircuits.com/showthread.php?t=81830)
    I need a sanity check with a simple circuit for using FTDI's FT231X chip.
    After many, many checks I'm pretty sure the schematic and board layout are correct:
    *Both source files, and .pdf printouts available. Source files are for EAGLE 6.5
    I'm not even hooking up the VREG. I only have USB power connected directly to the FT231X chip by removing the PTC and Diode and just using 0-Ohm resistors in their place. I can read ~5V before hooking up the FT231X. As soon as I do, the VIN drops down to 2--3V.
    Do I have some glaring mistake that I am failing to see?
    Thanks in advance for your help.
  2. enggricha
    May 17, 2014
    check the link to the files...
